I'm getting so frustrated over this. Here's the rundown in a nutshell:
Had a lot of rain and it's been crazy hot here in NEPA. Water was SLIGHTLY turning a bit cloudy. Shocked it. Next morning it was light green. My daughter and I went in, vacuumed a few clumps off the bottom, scrubbed the sides down, and shocked it again. Next day, still green. Went to local pool store and they tested as follows:
FC=8.6
TC=8.6
PH=7.6
ALK=117
CH=59
CYA=130
IRON=00
COPPER=.10
PHOS=382
They told me to add Regal Calcium Increaser. Did that. Next morning, CLOUDIER than it was before and darker green. Went back to local pool store and they tested and told me to use Metal Out for the Copper and it should take care of the green since it's most likely due to metals in the water. (My Copper went up by a 10th of a point?) See new test results below:
FC=.09
TC=.09
PH=7.4
ALK=109
CH=307
CYA=121
IRON=00
COPPER=.20
PHOS=439
Added that in at about 11am this morning and the filter has been running all day. Hasn't changed a thing. Pool store also told me to load up our floater with the 3" tabs (with CA Hypo) and we did that. Do we need to shock again? That's what the printout tells me that they gave me with our test results on it, but they didn't say anything about shocking right now. She said the pool should be clear by tomorrow morning, but the way it looks right now, I doubt it. Also, do I need to backwash after using the metal out? And when should I do that? Had the pool 2 years and has NEVER been like this. Always clean and clear!
FC=8.6
TC=8.6
PH=7.6
ALK=117
CH=59
CYA=130
IRON=00
COPPER=.10
PHOS=382
FC=.09
TC=.09
PH=7.4
ALK=109
CH=307
CYA=121
IRON=00
COPPER=.20
PHOS=439
