Help: Skimmer Basket Support Ring Comes off with Deck Lid
K8Luvs2Run
0
40
McKinney, TX
HI,
I need to re-secure my skimmer ring to my pool deck as it comes out with each time I remove the lid for the basket. Even more troublesome is that my dogs trip over it and risk breaking a leg :( Is there a recommended product and means of securing the ring back to the pool deck? Big thanks!
You need to chip out all the old mortar amd get that cleaned up. Put a large garbage bag In skimmer to collect debris. Use 3 taper head short stainless sheet metal screw in a triangle patter thru inside out the backside. When you mortar the lid in with a wet slurry amd then point it tight the screws will hold it down for good
Reactions: Texas Splash
