I an in-ground salt water pool with a Caretaker in-floor cleaning system. Water flows from the pump to a cartridge filter, then to the chlorine cell and then to the Caretaker 5-port valve. On top of this valve is dome-shaped coarse screen. I am getting a lot of mineral buildup on this screen, significant enough to cause my in-floor cleaners to not work and trigger the no-flow alarm on my chlorine generator panel. This buildup almost looks like coarse, flaky salt, see pics. This happens in less than 8 hours - I am running pool motor and chlorine generator constantly after shocking my pool due to green algae two days ago. I had not noticed the chlorine generator was shut down due to no water flow. I tested the water with test strips and everything looks ok. What can I do about this and why is my cartridge filter not catching it?
