Help reinstalling spa light
frechley
3
northern california
Hi,
I am not sure what type of spa light I have, but I removed it trying to fix it. Putting it back in the wall has proved difficult. The light is a pentair light, but the cord is too short to remove it from the water and there is no housing to attach the pilot screw. All I have is the plastered wall and a wedge. My assumption was that the wedge would somehow provide pressure against the plaster, but I can't seem to make that happen. Does anyone have advice? One additional detail is that I am pretty sure the lights are LED lights.
On a stupid side note, turns out I didn't need to remove the light anyways as all that was needed was to reset one the power outlet on the same circuit.
Thanks for any help!
Did you try tightening the screw in the wedge?
You see the way it wedges between the light housing and the niche?
Reactions: duade
