Thanks in advance!
IG, plaster, 25,000 gal, 1hp superpump, sand filter
I dumped a lot of Di-Chlor in the pool last week as that's what was on hand and I wanted to try to quickly halt growth at temps are in the 80's now in Texas. Added 12 lbs of Cal-hypo Thursday after reading that too much di-chlor could be bad. Finally was able to fo a full test this morning and this is what I have:
FC: 2.6
CC: 1.6
pH: 6.0 or below
TA: 40
CH: 70
CYA: 70
According to poolmath I should add the following:
34 lbs borax
10 gal 10% bleach
15 lb baking soda
46 calcium chloride
As this pools is currently in swamp state, I completely understand that I may need all that and more. My main question is, do I add that all at once or should I step in certain things one at a time whit checks in between?
Thank you!
FC: 2.6
CC: 1.6
pH: 6.0 or below
TA: 40
CH: 70
CYA: 70
34 lbs borax
10 gal 10% bleach
15 lb baking soda
46 calcium chloride
Thank you!
