Just got the Taylor 2006C Salt kit in and did my first round of testing. Brand New pool, construction finished late May, 7500 gallons plaster Wet Edge, no screen, direct sunlight all day. The pool builder has been balancing chems up until about 5 days ago... Pool looks beautiful, crystal clear. Looking for some confirmation on what I should and shouldn't be doing via results/ pool math suggestions. Thanks in advance for any insight!
Results were
FC - 3.0 - The Recommended target is 6.0 at 90 CYA - The recommendation is to run the SWG at 40% 7.75 hours a day.... It is already running at 40% 10 hours a day from 8am to 6pm. Should I up the Percentage or pump run time?
CC - 1.0
CYA -90 (Pool builder was using a lot of Dichlor I think)
PH - was high, Per 2 drops needed on Acid Demand Test to hit 7.6, Taylor book suggests 13.8 oz of 31.45%
TA - 70
CH - 220 - This is recommending to add 15 Lbs. of Calcium chloride? thoughts?
Salt - 3400
I'm pretty sure that adding the acid is a no brainer, but want to verify the other items before proceeding!
Results were
CC - 1.0
TA - 70
Salt - 3400
