carlscan26 said:The only place I see a possible concern (hard to tell with the angle of the pic) is on the suction side where the tube from the LQ connects to the valve (on the LQ side of that valve) the connection looks a little tight, almost like the clip-thingie is popping out.
Bama Rambler said:Aw, don't worry about clipping the ty-rap tails. In never clip mine, I think it adds character! I use different colors too!![]()
Bama Rambler said:The quick connects are really easy to disconnect. There's a little ring on the end of them. Just press and hold it against the fitting and the tubing will slip right out. When you're putting it back together be sure the end of the tubing is cut square and clean and press it in all the way.
Bama Rambler said:You have the same problem as the poster in the other thread. Your equipment is so close to the pool and your plumbing is so short that you don't have a lot of suction head. That's very good for the pool but bad for the LQ installation.
What you're doing by closing off the block valve a little is artificially creating some suction head that the rest of us have naturally.![]()
barnyard said:I was in the same situation you are in. My setup is pretty much the same as yours. Short runs from AG skimmer to pump, and not enough suction to get real good flow. I had my skimmer valve closed a little to help the flow, but didn't like that solution for the long term. I then moved mine to the pump basket and it increased the flow by a lot and I was able to open the skimmer valve all the way and I was still able to peg out the flow meter. It is worth a try. I had already drilled and tapped my pipe for the LQ before the pump, so I just moved the LQ outlet to the pump basket drain plug and then used the pump drain plug to seal off the hole in the pipe. You have nothing to lose by trying it and see if it works for you. It did for me.
barnyard said:I had already drilled and tapped my pipe for the LQ before the pump, so I just moved the LQ outlet to the pump basket drain plug and then used the pump drain plug to seal off the hole in the pipe. You have nothing to lose by trying it and see if it works for you. It did for me.
