- Jul 21, 2013
- 52,184
- Plaster
- Pentair Intellichlor IC-60
Thanks! Easily fixed.The IntelliChlor cell should be on the other side of the loop and flow up, not down.
Thanks for the catch! You guys are the best. Yes - I had it correct in my initial layout and then fit it up backwards. Just need to pull that loop off and flip it. Funny thing is I do have dyslexia, so I’ll just blame that.W,
Looks pretty...
But... Your SWCG is plumbed backwards.. Flow must be up and not down.. This keeps the flow switch from closing due to gravity.
I'll see what else I can nit-pick..
My solution - we’ll see how it works - was to slope the slab in that area toward the gravel where the suction lines come up. That 4” PVC is tied into a tile that runs 750’ or so to daylight in the woods. My plan is to cut the PVC just above the gravel but below the concrete, so if the ground was unable to absorb the water (would take an awful lot - there’s a lot of gravel under that slab), it would overflow into the 4”. If I vacuum to waste, I’m going to put a short piece of flex line or flat drain tube on that 2” line that I can route into the 4”. I also used PVC baseboard and set the SmartSide wall panels (typically used on the exterior of houses) on top of the PVC and caulked the tar out of it. My hope is that will keep the water out. If it did get back in the wall somehow, they are coated in closed cell foam insulation, which should not mildew or absorb water.W,
I assume you already know this, but equipment pads are wet.. Where is the water going to go when you open the pump lid or remove the filter drain plug???
I've wondered about that also. I think the manual calls for a straight run before/after, and that's what I did. I'll go back and look at that again.I think the loop you have for the vertical mount SWG is a little larger than you need. I have been running my vertical install IC60 as shown for a year and a half now with no issues.
Gary
Thank you! Easily changed.You'll want your sacrificial anode to point down or horizontally with a downish pitch, otherwise it tends to trap air in there.
I'm jealous of your equipment all nice and neat inside out of the weather. If I was being "nit picky" as my wife calls it, I might would bring the pump closer to the filter maybe a foot or two. Still leave yourself enough room to approach the filter and work around it to get the top off of it. But you could bring the pump over a foot and that would give you clear access to walk around the back and to your electrical panels without having to step over the pump. Again, that's being super anal about it, but just my opinion if your looking to optimize space in there.
Let him be with his friends you MONSTER!!! Poor guy all lonely in no-mans land.....It does kind of look awful long sitting out there though.
Haha, I don't think anything in those pictures looks "awful". I think it looks quite nice, and any other fellow OCD fan would agree!
My three sons would confirm that I am indeed a monster, and have made it my life's work to raise them into adulthood never having enjoyed a moment of it.Let him be with his friends you MONSTER!!!
