I have several things to fix. Need advice on approach.
One, I’ve got a hairline crack running along the plaster inside the spa. It’s big enough now it’s leaking water through steps of spillover. What do I use to fix that?
Two, I have grout in between each of the steps of the spillover that is loose and now the coping is loose. What do I do to fix this? Grout looks more like cement than grout. Do I put anything in between each coping layer to hold it in place?
TIA.
TIA.
