I had my solar installed in 2016 so everything except the panels is out of warranty. The solar company has actually been bought so technically doesn't exist. I'm not sure where to turn to get this issue resolved.
When my solar is on this valve electronically will push the water toward the top (to solar panels) and it doesn't leak
When my solar is off (much more common as the temps get higher) then this electronically bypasses the solar panels and water pours out of the middle of the valve.
I'll removed the top part (4 screws) and can see the "gear" that is uses to turn the valve. The water seems to be coming out of this gear. I verified all screws below and above were very tight and it had no effect on the leak, apparently something has broken and this appears to need to be replaced.
I've found the part (CVA-24T) seems to run between $100 and $150. I have no experience with plumbing my pool so I'd like to get any input on what it takes to replace this.
A) based on the description can this leak be repaired or does this part need to be replaced
B) Does replacing the part involve replacing the 3 way valve in the plumbing
C) I see the electric coming out of the valve going to my pentair controller, is there any complicated wiring or programming that needs to be done? I have a pentair solartouch controller this connects to.
Thanks in advance!
Thanks in advance!
