We took a spa a few nights ago with no problem. This morning set it to Spa mode with the heater on, then a few minutes later I noticed a strong overflow from the spa to the pool (pool mode had kicked in, but at a much higher gmp/rpm than usual for pool mode). I turned off pool mode and spa mode continued to have this strong overflow to the pool. I gave up and just now took a look at it.
My set up is that actuator 1 and 3 should be pointing north when in spa mode and both pointed south for pool mode. Though currently when in spa mode actuator 1 is pointing north and actuator 3 is pointing south.
I thought the small pin on the front side of #3 may somehow have been knocked out of position, so I went to move it, and it literally fell off in my fingers. Attached photo shows a spring sort thing that slides out of the pin.
Question one:
Is there anything I can do to manually set actuator 3 to point in the correct position so we can heat the spa, then return to to its current position to filter the pool?
Question two:
Is this a repair I might consider to do myself?
Thanks!
York
Question one:
Question two:
Thanks!
York
