I currently have a number of old plumbing pipes terminating in my pool pump area that aren't labelled or known and arent connected to anything. I know my pool is 1986 era - found the year marked on an old SPA blower.
I used a spa blower to blow down the old pipes to see where I saw bubbles to help me identify where each were connected. See below photo - this is what I found:
1) Wall jets. Its currently an open pipe in the pumphouse with nothing attached.
2) Seat Air Jets - currently connected to BLOWER UNIT 1. Working
3) SPA Suction going into Pump. (3 way valve here, 1 INPUT from SPA, 1 INPUT from Pool skimmer). Working.
4) Its currently an open pipe in the pumphouse with nothing attached.
5) SPA Return. Working
6) Floor Air Jets - currently connected to BLOWER UNIT 2. Working
7) Doesn’t appear to be connected. Yet to remove the cover as yet.
8) Unsure what this is
Can someone please advise of the following:
7 and 8: What are these for considering that the SPA suction and return is currently using ports 3 and 5?
1: Wall jets - this is normally water fed isnt it rather than air fed? If so, should it be fed via a pump that has high output (Eg a VSP setup). If so, then I need to buy a new VSP here. I only have single pump that is single speed today and as noted, there is nothing actually attached to this pipe in the pumphouse.
2 and 6: Assume these stay connected to the air blowers. Both blowers are 1200W. Should they share the same blower (maybe have a 3 way valve here)?
4: What on earth could this be for or what was it used for historically?
Pool season just opened - my plan is to start to buy what new valves,pipes and couplers I need to refresh the setup and tackle this in a few months time. Understanding the answers to teh questions will help me determine what kind of setup I will need to have with valves etc.
