We have decided to put in an inground pool and interviewed a few local builders.
We have narrowed our search down to two builders. One is Vinyl and another is Gunite.
Pools are relatively similar with just small changes between the two.
Vinyl:
16’ x 32’ Vinyl Pool
27 Mil Liner
6’ Full Width Sunshelf with Bubblers
Variable Speed Pump
Salt Chlorinator
LED Lights
Automation
Heat Pump with Chiller
Unilock Paver Deck with Stone Coping
Wall Block Retaining Wall
Gunite:
16’ x 32’ Gunite Pool
6 x 12’ Sunshelf (Outside The Pool - Making a Larger Pool)
Deck Jets
LED Lights
Variable Speed Pump
Salt Chlorinator
Automation
Stone Coping
Stamped Concrete
Poured Concrete Retaining Wall with Stone Facing
As you can see, the are nearly the same pool with the exceptions of material (Vinyl vs Gunite), Sun Shelf is outside the 16’ x 32’ on the Gunite, Pavers on the Vinyl and Stamped Concrete on Gunite and the retaining wall styles (block be concrete)
The gunite is around $15k more expensive. We are concerns about maintenance, longevity, chemical balance.. etc.
Which is the better pick here?
Vinyl:
27 Mil Liner
Variable Speed Pump
Salt Chlorinator
LED Lights
Automation
Gunite:
Deck Jets
LED Lights
Variable Speed Pump
Salt Chlorinator
Automation
Stone Coping
Stamped Concrete
