We are looking to build a 18x40 rectangular pool with an automatic cover and a 3.5/4' depth to 5' with a 10' deep hopper on one end for diving.
We have two local pool builders both are reputable. We honestly have good feelings about both of them.
I have received quotes from both and they are within 4% of each other however they have different brands of items and we don't fully understand what everything is so we are unsure which is truly the better deal. Any advice would be appreciated. I left the prices off but for comparison sake lets just assume they are the same. Which would you prefer and why?
Builder A:
Our gunite swimming pools are built with the highest quality materials and design features. While some pool contractors will cut corners, We build every pool with all rebar placed on 8”-10” centers for a structurally superior shell. Our standard pools include travertine coping rather than concrete or brick products. Our standard lights are LED white lights rather than incandescent lights. Our standard interior finish is a Quartz product rather than regular Marcite plaster. All of our equipment components are Pentair products and come with a 1 to 3 year warranty. We are a certified Pentair service center, giving us the ability to more efficiently service our customers.
Swimming Pool:
Gunite swimming pool – 18’ x 40
4’ – 10’ depth (10’ hopper under platform)
Bahama ledge (6” water) in combination with steps
2 fountains and 1 umbrella receptacle in the Bahama ledge
Bench with step-out in the shallow and deep end of the pool Additional step-outs and benches at customer’s request
6” waterline tile (upgrade options available)
12”x 24” travertine coping
Level 1 quartz interior finish (upgrade options available) 2-Pentair LED white lights
1-2.0 hp Pentair whisperflow pump
1- Pentair TR100 sand filter
Pentair Mastertemp 400,000 BTU natural gas heater (or propane) Pentair IC40 Intellichlor automatic salt system
Pentair automatic filler
2 High Flow Skimmers
Timer/Freeze Control
Minimum of 5 return lines with eyeball fittings
Main drains consist of an anti-vortex, anti-entrapment VGB compliant 32” channel drains We are the only local swimming pool contractor currently providing this safety measure
Dedicated Vacuum Line that is VGB compliant with a spring-loaded door
All plumbing is run in 2” and 2.5” Schedule 40 PVC for ultimate water turnover rate Net/Pool Vacuum/Brush/Pole
Start-up chemicals
Test kit
Full orientation of all equipment
4’ of stamped, integral colored concrete deck is included with pool installation Additional concrete is available at $8.00 per square foot
COVER: Automatic pool cover – exclusive vinyl fabric formula reinforced with mesh for strength and resistance provides maximum durability. Power touch security control pad instead of a switch. Custom cover stones instead of an aluminum lid.
SPA: Interior spa with 8 jets, air blower, 2.5 HP variable speed, high efficiency Pentair pump, 1 Pentair LED white light and a VGB compatible main drain
AUTOMATION: Pentair Easy Touch 4 Function automation load center panel with actuators and wireless remote control with charging base
Builder B:
18' x 40' Rectanglular shaped gunite swimming pool
3.5'- 5'- 10' Depth
Bahama ledge with step-outs (Fountain and umbrella sleeve in bahama bench)
Additional step-out's and benches at customers request at no additional charge
6" waterline tile)
White or Blue Standard Plaster Finish
Hayward Tristar 2.0hp for pool, 36" sand filter
Hayward Automatic Chlorinator
2 - Hayward 500w light for pool
12"X24" Pre-Cast Coping
Dual Drains, 4 returns
Automatic Filler
2 High Flow Skimmers and a dedicated Vacuum Line
4' Salt Finish Concrete Decking Around Pool ( Additional concrete at $3.75 per square foot) Net/Pole/Pool Vacuum/Brush
Test Kit
All Start-up Chemicals
All Utilities furnished to pool equipment area by others - Not included in bid
Licensed Electrician to supply electric panel to equipment and do hookup - Not included in bid Licensed Plumber to hook-up gas line and gas heater- Not included in bid
Excluding any utility relocates
Excluding any sprinkler repairs or relocates
Should equipment be located indoors, venting of equipment to be done by others
INCLUDED OPTIONS
Option 1: Coverstar Automatic Cover, Lid to be Stainless Steel
Option 2: Upgrade to Tahoe Blue Quartz Plaster Finish
Option 3: 8' spa to be contained in pool
8 jets
1 - 2.0 Hayward Booster Pump 1 - 2hp Silencer Air Blower
1 - 100w Hayward Light
1 - 400K BTU Hayward Heater
Option 4:Hayward Omni Logic Automation
Option 5: Led Lights for Pool and Spa
Option 6: Upgrade to Travertine Coping
Option 7: Hayward Heat Pump
Builder A:
Swimming Pool:
Start-up chemicals
Test kit
Builder B:
3.5'- 5'- 10' Depth
6" waterline tile)
Automatic Filler
Test Kit
INCLUDED OPTIONS
8 jets
