What does that mean?Maybe the sand is channeling?
That would have nothing to do with the water level in the pool, and the pool is clearing slowly so that shouldn't be a problem.Maybe the sand is channeling?
Channeling happens when sand gets over saturated with years of grime and goo. It means the gunk in the sand has hardened somewhat and the water has carved channels into the sand, so a lot of dirt passes through the channels and back into the pool. I don't think that is your problem.What does that mean?
I dont have to dig up the part that is under ground. But wouldn't it be pulling in dirt if the leak was under ground or would the filter it before i coukd see it? And also I just had my sand changed like 3 weeks ago. So yeah I don't think it would be channeling but I'm not the expert.Channeling happens when sand gets over saturated with years of grime and goo. It means the gunk in the sand has hardened somewhat and the water has carved channels into the sand, so a lot of dirt passes through the channels and back into the pool. I don't think that is your problem.
Check all the hose connections between the skimmer and the pump and make sure they are tight. You can check for an air leak by smearing a little shaving cream or really foamy soap suds around the edge of the hose. If you see the soap getting sucked in then you have an air leak. If the soap just sits there the connection is good. Some of the soap will drip and fall off, just watch for any being sucked into the hose opening. You may need a small mirror to see the underside of the hose.
Good call.Maybe the sand is channeling?
Thanks...I will try that tomorrow. I started with the soapy water and was having a hard time....that seems like a easier way to test.Air leaks are on the suction side, between the pool and the pump. Once it leaves the pump for the filter is the pressure side, and any leaks would squirt water out instead of suck air in. Air can be sucked in from lose plumbing connections, such as hose clamps that need to be tightened, glue joints that have weakened, o-rings on pump pot lids that need lube, loose pump pot drain plug, low pool water level, and a visible vortex in the skimmer. One of these conditions is going on for it to be sucking air. If you have pvc pipes that are partially buried dirt would usually seal up the leak. It wouldn't suck a lot of dirt into the pool. You can also test for leaks by running a water hose over each glue joint, drain plug and pump lid.This video shows how that works.
So will this improve or speed up the process that much? What should I expect when I add the DE?Good call.
Adding DE sounded like a good idea until you mentioned that. The water is cloudy enough now that if the DE blows through, he won't see it and it will get worse. I just went back and checked. Already had new sand recently.
So go ahead and add DE or cellulose DE replacement
So will that shoot out anything into my pool? I was wondering if I will see any changes there?You add a little bit of DE to the skimmer, about a cup's worth. It will form a layer on top of the sand bed in the filter and capture smaller particles than the sand does. Expect the filter pressure to rise more quickly, as the DE is taking up space in the filter and will trap more dirt. Backwash when filter pressure rises by 20%. Fresh DE will need to be added after a backwash.
Like foaming or stuff floating....etc.So will that shoot out anything into my pool? I was wondering if I will see any changes there?
It better not. But if it does, then you'll know your problem is in your filter.So will that shoot out anything into my pool? I was wondering if I will see any changes there?
Also I've noticed my pump basket isn't filling up all the way with water like it use to. I see bubbles coming out the return now alot. The water level sits just below the lid now...but my water level in pool is good. I've read on other people's forums about maybe a leak or maybe bleeding the air line and I don't think I have one of those. I'm not sure though....how would I fix this? And would it be causing any problems with my water being cloudy?
And fun....Makes testing for things like calcium where there is a lot of swirling much easier.
Okay...I think I'll go ahead and try it.Entirely up to you. D.E. May speed things up a little, but eventually the filter will clear the debris if you keep the pump running.
