I had an in-ground pool installed this past August/September. I've been very happy with it so far. It's an 18x40' with oval ends and steps in the shallow end, about 32k gallons. There are two returns in the steps and a return in both the shallow and deep ends. It's a salt system, it's been really easy to maintain, the water is beautiful, but it's already getting too warm. I'm in north Alabama and the pool's water temperature late in the day yesterday was about 87 degrees. It's only mid-June, so I figure by late July the water will be unpleasantly warm and not refreshing at all, unless I can find a solution. To remedy that, I purchased
this...a waterfall pool fountain. I was told it would reduce the temperature by several degrees. But the streams of water are not going very high into the air. I have closed off the two returns in the steps, but even with that the water only sprays about 8' into the air.
I have a pentair Sta-Rite SuperMax pump. Specs are below. It's a single horse motor.
Product | Model | Voltage | Full Load Amps | HP | SF | SFHP | Primary Listings and Certifications3 | Port Size (NPT) | Carton Wt. (Lbs) | Curve Key |
PHK2RA6E-102L | N1-1A-HP | 115/230 | 14.2/7.1 | 1 | 1.25 | 1.25 | UL1, NSF2 | 1.5" x 1.5" | 38 | G |
It's mated to a Criscal-Flo II top-mount sand filter.
CRISTAL-FLO II TOP-MOUNT SAND FILTERS |
| | | | Turnover Capacity (In Gallons) | | | | | |
Product | Effective Filtration Area (Sq Ft) | Max Pressure (PSI) | Flow Rate (GPM) | 8 Hour | 10 Hour | 12 Hour | All Sand Required (Lbs) | Carton Qty | Carton Wt (Lbs) |
145362 | 3.15 | 50 | 70 | 33,600 | 42,000 | 50,400 | 300 | 1 | 58 |
I think I have at least two options here...I could try and choke down the flow by replacing the other fish eye with one that has a smaller opening. The other solution is to replace the motor and impeller, which could cost up to $400. The pump and motor seem to work perfectly for cycling the water, but it doesn't seem to do the job for getting the water to spray up in the air to cool off the pool. I'm going to try the cheaper option first of replacing at least the one fish eye, but does it seem like the 1hp motor is underpowered?
Thanks in advance for any input/advice. Please keep in mind that I've never had a pool before, so all this is very new to me and I'm trying to learn. Thanks, everyone!
