I was reading up on the sparkle conquest . It does say to treat the pool, turn off the pump and let the precipitate fall out and vacuum up the next morning, then repeat the process daily until there is no more precipitate in the morning. If I am reading this correctly you can add chlorine between doses.
You probably got a mini algae bloom started when the FC was 0. Keep raising the FC to your target range for a CYA of 45.
Do you know where the metals in your pool water came from?
