Opened to a green pool which is probably due to high CYA after years of Chlorine Puck use. They were 115 ppm before. After draining 8000 gallons from a 30000 pool, we ended up at around 90 ppm. Alkalinity is around 50 and PH is what I think is 6 or above. Can't tell with that one because the color is well below the test color for PH (it's yellow and the lowest was orange at 6.8) and this is after adding about 40 pounds of baking soda. I've added about 3 gallons of liquid chlorine to try and at least delay any further growth. If I understand the calculator right, I need about 8 gallons of 12% liquid chlroine to successfully SLAM after that, add whatever needed each day? It's weird my PH just doesn't budge no matter what I add and yes I do rinse after each use. Don't know what level of algae we're at with this color.
