- Jul 21, 2013
- 66,739
- Plaster
- Pentair Intellichlor IC-60
Thans for the replies! I'm a complete novice with this but safety is my #1 priority and I just want to make sure Im doing everything right.
Like I said the pool light timer is powered by an outdoor plug (which has a fuse thing) I believe is GFCI protected. If you look at the picture I posted above (and in this post) the plug is to the right of the box. After that box is plugged in, a wire is connected to the "Circuit #1 Common 300 watt max" and the "low volt hot 11 volt". This wire goes from the box into the conduit that runs underground.
Running a connection like that from an outlet to some junction box is against code. Things sound improperly grounded and/or bonded. You should not be connecting the hot and neutral lines without the ground connection. Pool lights are not allowed to be connected from an outlet through a timer into a connection box like you have.
We can’t begin to diagnose the wiring you have through an internet forum and you do not have the knowledge to properly describe the wiring to us. It takes an electrician on site to figure it out.
Just because the light works does not mean it is safe.
