I joined photobucket and I tried to upload a photo and sense it here but it didn't work. I uploaded it to this website. The pool looks lighter green in color but it is sunny today.
I turned the pump back on this morning, with the valve almost at the 9: position. The skimmers are working with the drain almost off.
The pressure gauge is now reading 17 PSI, the lowest since I installed the new gauge 2 weeks ago. All the returns are appear to be moving water at a higher rate.
Is this due to turning off the pump for about 14 hours or because the drain is almost off?
The FC has been holding during the SLAM ever since I started testing with the k2006. I test once per day and the FC is holding up well, always above shock level.
I will hold off on renting the trash pump and concentrate on the filter deep cleaning. I will do vacuum to waste with the valve turned to the skimmers and cover one of the skimmers
I had socks on the deep return and one of the shallow ones but there was no sand. I do see sand coming out of the pipe when I Backwash and vacuum to waste.
Suction from the skimmers were not working when the valve is at 9: position..and the drain off. I turned the the valve slightly and the suction returned. The drain is almost off but not completely. Is this normal?
