Hi all! I’m struggling trying to think about the best way to plumb in a Circupool RJ60+ in my setup. The return line is a little over 20”, which I don’t think is quite enough room for the 15” Circupool cell plus the 4” flow switch even if installed inline, just because I’ll also need some leeway for the joins.
The issue is that there’s another pipe just above the return line, meaning I can’t do a vertical installation of the SWG without either first jutting out a bit or adjusting the pipe above. I’m curious what you all think makes the most sense.
Thank you so much for the help.
