- Jun 24, 2021
- 16,349
- Vinyl
- CircuPool RJ-60 Plus
Trust pool math. Follow the recommendation for what to add. Keep testing and adding.I'm finally ready to start SLAMing my pool. I cleaned the filter cartridges, learned how to work the pump, pH adjusted to 7.5, CYA added (still dissolving overnight but almost at 30ppm).
The thing is...I am confused about how much liquid chlorine to add in order to bring the FC up to shock level of 12ppm
This morning my FC was 1 and CC was 7
So I added 3 gal of "Pool Essentials" brand 10% liquid chlorine
I waited 30 minutes with the pump running and then sampled. The FC had only risen to 2ppm. The CC apparently dropped to 2ppm (?)
I'm not sure if the liquid chlorine has lost its potency or what. I don't see how I can get to FC of 12 by using this stuff...poolmath says it should only take 1.8gal to raise FC to 7ppm but that is clearly not the case.
Any advice?
You may have old bleach. Have you checked the date code?
Chlorine Date Code Decoder - Further Reading
We got you...we'll get your pool cleaned up...
