- Oct 14, 2024
- 22
- Plaster
- Pentair Intellichlor IC-40
Hi all!
Quick question.
I have a Sta-Rite SR400NA, and it says to not operate it consistently when the water temperature is below 68F.
For my pool, I have an attached Spa. I am able to isolate the spa so that I only filter and heat water from the Spa. Is it ok to heat the Spa occasionally from below 68F (current water temps are in the low 50s) as long as I run the spa up to operating temp (100+)?
There is a note in the documentation stating that it is ok to run the heater when opening the pool for the season, so I imagine this is no different than that. Only difference would be I would probably do it a few times a month, and that it would take less than an hour to get the spa to temp and then maintain it.
Quick question.
