I have a Pentair MasterTemp 400 spa heater. Yesterday I noticed that the water temperature of the spa was below the minimum set temperature of 77F. The heater light on the EasyTouch control panel was illuminated; but the heater itself wouldn't fire. On the readout display on the heater itself, there was a code "E01" & the "service heater" light was on. On the underside of the display, the LED7 & LED11 were also illuminated. No other LEDs were illuminated. Unfortunately, the user manual for the heater made no reference to either of these LEDs. So I am at a bit of a loss as to where to start diagnosing. Any guidance that you can provide would be greatly appreciated.
In the meantime, I plan to clean the filters, inspect the internal bypass & check the thermal regulator.
Thank you for any help you can provide.
Kit
Kit
