- Jun 8, 2019
- 4,581
- Vinyl
- Pentair Intellichlor IC-60
I think I'll just wait for the service guys and see if I can hang around while they clean it, pay attention to what they do.
Is there any downside to getting a heater that's rated too high on BTUs aside from initial purchase cost?
Is it just the pipe size or is there some sort of rate of flow that I need to worry about? I can measure pipe size myself, but I would need an HVAC place to measure rate of flow.You need to verify that the meter and gas line are big enough for the new heater.
Meter and heater are close but I don’t know how direct of a run there is. Meter is stamped with 250 CFH so it looks like I should probably stick to my current size of 200k BTU. I can’t tell the inside diameter of the pipe right now. I’ll ask the pool guys when they stop by to troubleshoot it.The meter should have a label that says how many cubic feet per hour the meter will do.
Usually, the model number will be the cubic feet per hour.
One cubic foot per hour provides 1,000 btu per hour.
So, a 250,000 btu per hour heater will require a 250 cubic foot per hour meter.
The gas line depends on the length and btu/hr required.
What is the distance from the meter to the heater?
What is the current pipe size?
Note that the pipe size is the inside diameter and not the outside.
I’m still having the guys come by to clean it out. Though when I asked about that they sounded pretty hesitant, like it was a real PITA to take apart. At the very least I’m going to have them check out the controls. The end of last year showed that even all the way down it was still running at 80-85 degrees.Thanks for the follow up and glad you're in business again. I'd take it apart as Allen says and blow it out with compressed air or get the service tech out to do it. At end of season a few squirts of bug spray around the base and at pipe/electrical penetrations wouldn't hurt.
it’s more about how the old parts break while coming apart and won’t go back together. Then it’s blamed on them and not the age of the heater. You might get the disclaimer speech before they touch it. ‘Will be extra careful, no promises,’ etcthey sounded pretty hesitant, like it was a real PITA to take apart
I left my heater on one night, looked out the window and wondered why steam was coming off my pool![]()
