We have an approximately 40k gallon pool in the Houston area. What I am trying to find help with is deciding on what size pool heater (must be an electric heat pump type since no access to natural gas and do not want to incur the cost of a large propane install) for a very specific use. I ONLY want the heater to help warm the pool early in the season to take advantage of warm/hot days where the pool may not have had a chance to come up to a comfortable temperature. Also, maybe extend into the fall a bit. I do not need it to heat the pool during the winter and during the summer months, the air temperature in Houston is more than enough to keep it warm. I would like to find a solution as cost effective as possible and have no problem if a smaller unit may take a day or two to accomplish the task. How small a unit can I go to achieve the desired result?
Thank you!!
Thank you!!
