New pool owner, and first post…be gentle. I have searched and read several posts which have similar issues to what I am having but could not get a clear answer. I have added my equipment in my signature below (hopefully it shows up) to help you help me.
PROBLEM: The temperature set point shown on the heat pump control panel does not change when I adjust the set point on the EasyTouch control panel. This means that I cannot force the heater to turn on by using the EasyTouch control panel and I must manually adjust the set point on the heater itself. It appears the heater works fine when I manually adjust the set point.
WHAT I HAVE TRIED: I have set the temp set point to 104 degrees on the heaters control panel in hopes that the EasyTouch will turn the heater on/off based on the temp set point on the EasyTouch. When I do this, the heater runs constantly which is undesirable
HOPEFUL SOLUTION: please help me configure my system so that the EasyTouch can control the temperature of my pool/spa. I am attaching a picture of my EasyTouch control board to show how it is wired.
Thanks in advance for your help!
