U utah pools Member Apr 24, 2024 5 Utah May 24, 2024 Add bookmark #1 Pentair 400 series only 3 years old doesn’t heat 10x10x3 spa very fast. Takes 60-80 min to raise temp 14 degrees. Is this normal? If not what’s wrong
PoolGate Gold Supporter TFP Guide Jun 7, 2017 9,469 Damascus, MD Pool Size 29000 Surface Plaster Chlorine Salt Water Generator SWG Type Jandy Aquapure 1400 May 24, 2024 Add bookmark #2 Has it always been this way?
ajw22 TFP Expert Gold Supporter Silver Supporter Bronze Supporter TFP Guide Jul 21, 2013 55,441 Northern NJ Pool Size 35000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-60 May 24, 2024 Add bookmark #3 Post pics of the data plates on the house gas meter. What is the CFM of the gas meter?
JJ_Tex Gold Supporter Bronze Supporter TFP Guide Jul 17, 2019 3,787 Prosper, TX (DFW) Pool Size 13000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-40 May 24, 2024 Add bookmark #4 And what RPMs do you use when you heat the spa?
