I had a new pool last year by a fairly unreliable pool builder. Not a good experience. I've got the pool back up and running and have purchased a better pump as well. Everything was new and provided by the pool builder except for the heater which I purchased used from someone. The pool builder did however hook up the pumping to it.
I opened the pool about 2 weeks ago and everything went fine. Water is not crystal clear after using bleach for the first few weeks. Salt generator started working yesterday as the water is not 55 degrees. My Easytouch has both a water temperature sensor installed as well as an air temperature sensor. Yesterday, for the first time this season, I turned on the heater and everything worked fine. Heater ran for a couple of hours without issue. Since I just pruchased and installed Screenlogic 2, I downloaded the instruction manual and tried to connect the heater to the easy touch so I can control from there instead of the heater itself.
I removed the jumper at the fireman's switch and ran a 18/2 wire to the easytouch. I connected to the heater 24v at the top of the easy touch. While connecting to the heater where the fireman's jumper was connected i accidentally touched both sides at once which blew the fuse there. I replaced that fuse and connected the wires to location where the firemans jumper was connected. I then restored the power and turned on the heater from the easy touch. The heater did not fire, but about 10 seconds later I heard a poof, saw smoke and smelled horrible burning small.
I then disconnected easytouch wires and replaced the firemans jumper and the heater would no longer even turn on. Mainboard is fried and I can see where it was. I found a local source to pick up a new board today I am hoping will solve my issue.
What did I do wrong here? I really want this to be hooked up to easy touch but I really don't want to fry another board. These things aren't cheap
Any advise here would be appreciated.
Thanks
Thanks
