Heater for outdoor bathroom
Nov 8, 2016
40
Bridgewater, NJ
Hi All,
I am building an outdoor bathroom in NJ. Winters can be cold. Wondering about installing a portable space heater in the bathroom for winter purposes. The pipes will all be winterized but wondering if there is any need for a space heater in there.
Thanks in advance.
What I would do is put a cut off valve on the pipes that lead to the outdoor bathroom at the house. I would make sure to also have a drain valve to be on the extra safe. One of those better safe than sorry times.
Kim:kim:
Hello,
we we had a pool house built last summer and had this heater installed. Works great. It has its own thermostat.
Cadet Com-Pak Plus 9 in. x 12 in. 1500-Watt 120-Volt Fan-Forced In-Wall Electric Heater in White-CSC151TW - The Home Depot
Mike
Thanks for the quick reply. So for my bathroom, why not just use a space heater that I can plug in for the winter as opposed to this which requires a dedicated line?
Lastly, whats the fire hazard with either of them given its outdoors where I will not be checking daily?
Thanks again.
Running a space heater is going to increase your electric costs. When you look for a heater, look up the specs so you can figure out how much it will cost to run 24/7. As for fire risk, anything that is close to the heater, including walls should be non-combustible. Most heater specs will state how far they must be from combustibles to operate safely.
I would only run a heater when the risk of a prolonged hard freeze was great.
I can only speak to the heater I had installed. It is on only 20% of the time and only came on when the inside of the pool house was below freezing. I winterize the pool house so the heater may have been overkill but I thought it can hurt to keep the dampness out. My cousin has a large pool house in Conneticut that has no heater and he never had any problems.
