I cleaned everything and I don't think it is a flow issue. Flow may not be optimal but from the pool I am getting 50GPM-75GPM depending on RPM so I think that should be enough. When checking manually, I am getting the same pressure in the SPA that I used to have before.
I am fairly sure it is a heater issue. So what happens is the following:
1. it clicks, the gas valve opens and the ignitor does sum periodic wumm-wumm-wumm sound. I think the heater is somewhat igniting but when everything was working before, the heater used to emit a much louder and more constant burning sound and a not the periodic wumm-wumm. It gets a little warm so sth is burning and it smells of gas.
2. When I measure the fc+ and fc- pins with my multimeter it shows 300-400mV DC (don't have a true-RMS)
3. after a couple of seconds it clicks again and then the FC pins show 0V.
I double-checked the ground and added an additional wire between the control box and the burner. Everything looks perfectly clean and well. I exchanged the thermal regulator. No LEDs are on on the backside of the panel. When the heater is trying to ignite, the heating LED is blinking.
Could it be the flame sensor? Where is it and how can I clean it?
