Just looking for suggestion, I’ll likely get someone out to service the hot tub.
It’s a royal spa empress. I don’t know it’s history, we bought a house a few years ago and it came with it.
Last year I had some issues with the gfci. breaker flipping and it got worse overtime to the point it would trip as soon as I turned it back. I replaced the breaker and that appears to resolve it but now a year later it’s going it again.
at the same time I also have some issues with the heater/control panel. Sometimes when the heater would kick on, it will just flip on/off/on/off very fast (the light on the control panel also goes on/off). Sometimes it would do it a few times and be fine without me touching it. Others I could get it to stop and heat correctly by moving the temp gauge back and forth until it stayed on. There has been several times I have come out to the hot tub being cold and the heater not on until I move the controller just right.
another thing that could relate to both items is the last couple times we used it the breaker flipped when turning the lights on but that is the first that has happened.
my thought was the control panel could be going bad and maybe I should just replace it and hope that solves the heating problem and just maybe solve the breaker trip issue but after reading some things I could be issues with something else.
im thinking maybe I’d be better off spending the money to have someone come a service it and see what they think the issue is. I should be able to replace the control panel myself but if I start getting into tracking corroded wiring I think I’d rather just have someone else look at it.
Any thoughts on the issue? It could be 2 separate issues but I’m hoping it’s one thing causing both but don’t know much about the electronics of a hot tub.
