Hello all
I'm stuck. We have a 13,000 gallon above ground 24' pool in Southwest Ohio that gets direct exposure to the sun for every second the sun is out (which is a lot in the summer). Last year we had an unusually hot summer and we sat in the upper 80's. This year is a different story. We're camping around the low to mid 80's and with the solar cover (16mil gray) we're floating 75-77 degrees.
Our goal for a heat pump (propane is not an option - too expensive to run) is to be able to get the pool to sit at 80 degrees or higher for ALL of June through September. Hayward indicates that I need a pump around 65,000 BTU. Unfortunatley, the only ones I can get my hands on are 47,000 (for $2,299) or a 90,000 (for $4,000). I really would prefer ot not spend the extra $1,700 (especially since it's 4-6 weeks out on delivery and the smaller one is in stock).
Anyone have any experience trying to heat a larger body of water with a slightly undersized heat pump? If I could get my hands on the HP70HA2 (70k btu unit) I would but I can't find it in stock anywhere.
