the heat pump is working right now, air temp is colder than it was last night, I just don't get it!
Flow can slow over time due to algae clogging the filter. Some of the algae can settle off the filter when the pump stops and then the cycle repeats.
Do a Overnight Chlorine Loss Test and see if you have an algae problem brewing?
hmm
if I was to take the HP off the remote setting, I SHOULD be able to manually set the HP to SPA? That SHOULD let it keep working until it hits 104...right? Once it is off the remote setting, it should use on board temp sensors and pressure sensors to decided to turn on or off?
