1st post and hoping someone has experienced this and can help. I went to check on my pump this morning and it was dead, nothing on the screen and no lights. Turned off the power and the breaker and went to remove the control panel and water just poured out when I loosened the screws holding in place. The board is shot, pics attached and also the 6 pin connector coming from the motor that attaches to the display connector on the motherboard looks corroded as well. I found a new display unit.
Here's my main question. Has anyone ever cut and rewired that cable that comes from the pump motor? Ideally I would take a pic of the wire color order and cut off the end and rewire those cables to a new connector, just not sure which connector I need. I found a JST-XH connector that looks similar, but not sure if that's the right one.
I've attached some photos for reference. Your help is appreciated!
