Was checking the pool this morning and noticed that the filter pump (Hayward Tristar SP3202VSP) was not running. Checked the pump diagnostic on the Omnilogic, and it reports a "DC voltage is too low" error. According to the troubleshooting guide in the pump manual for this error, it states "Indicates that the DC bus voltage has dropped below 230 VDC. Verify that line voltage is within 10% (207-253 VAC) at the terminal block." So I checked the line voltage at the terminal block of the pump, and it is 240 VAC as it should be. Suggestions on next steps?
