- May 18, 2015
- 356
- Plaster
- CircuPool RJ-60 Plus
Ugh, my second post of the day. Not a good day for me.
First day with the new Hayward SP2603VSP setup.
It was running fine for about an hour. Then I heard it shut off. Display said DC VOLTAGE TOO HIGH. It reset itself, went into an auto prime, got the same error. It repeated this about 4 times in a row and now is running again.
My voltage at the pump is 249 VAC.
Pump spec says +/- 10% of rated motor voltage. Motor plate says 240/230.
At 240 that’s a range of 216-264 Vac
At 230 that’s a range of 207-253 Vac.
Either way, I’m in range.
Thoughts?
Thoughts?
