The SWG is able to produce 1.45 pounds per 24 hours. Using this you can simply select in the settings any SWG model (the Circupool RJ-30 plus makes 1.5 per day) and simply enter 1.45 into the field for SWG chlorine output. This will update all the fields across the app to provide the correct calculations.
