Just upgraded to a tristar 3202 vsp from a super II. My Super II was connected to the filter relay on my e command 4 along with my Aquarite generator.
Does anybody know the correct way to wire the pump to the controller, the Vsp is compatible with the e command, but I am not sure how to set the DIP switch so it will communicate.
I tried using the com cord that came with the pump and wiring as suggested using 3 wires but I get a communication error on the e command, , in the e command manual it says use 4 wires, I've also seen instructions online using 2 wires for communication and to set pump address at 001. So at the moment I'm lost!
Any info would be greatly appreciated.
