The cycle time should be 180 minutes.
At 20%, the power should be on for 36 minutes and then off for 144 minutes.
You can confirm by watching after Reversing Polarity and timing the cycle On time.
1. With Firmware Revision 1.55 (5/8/2009) the cycle time (reversal of polarity) changed from 120 minutes (2 hrs) to 180 minutes (3 hrs).
When you set the ‘Desired Output %’ dial on the main panel this sets the level of salt cell operation as a percent of the operating time of each cycle.
50% is the factory default.
Below are simple examples for 2 and 3 hr cycle times.
• 2 hr cycle: If the output is set at 50% and the total time for operation is 8 hrs, the salt cell will operate (and produce chlorine) for 50% (1 hr) of each 2hr cycle for a total of 4 hrs.
• 3 hr cycle: If the output is set at 50% and the total time for operation is 9 hrs, the salt cell will operate (and produce chlorine) for 50% (1.5 hrs) of each 3 hrs cycle for a total of 4.5 hrs
