Hello - So I just went through and replaced the gasket, impeller, seals, etc. via a maintenance/go kit. I used this video:
http://www.inyopools.com/HowToPage/how_to_replace_a_motor_shaft_seal.aspx
https://mail.google.com/mail/u/1/#inbox/146c3a82b1cbddff
Which helped me every step of the way. Turned on the pump, still behaving the same. I had to work up enough water between the skimmer and drains/jets to get the pump to work, but the water is still coming out of the bottom pretty heavily, not dripping. It's more of a stream of water than a drip. Any ideas what I should try next? It's really hard to see where the leak is coming from since it's on the bottom, but it's definitely what seems like in the area of the bolts that connect the motor and stuff. Sorry I'm not so pool savvy. Any ideas?
I attached pictures so give an idea of the type of pump I'm using.
Thanks!
Thanks!
