It's 1/4" npt. Most drain plugs are 1/4" npt.
The newer drain plugs are designed with an O-ring.
The O-ring plug is preferable if the pump hole has a flat spot for the O-ring to mate with.
A 1/4" npt plug will work in any case.
Hayward Super II SP3000 Series - INYOpools.com has the largest selection of swimming pool and spa replacement parts with over 70,000 parts in stock. Order today and save!
www.inyopools.com
1991 and earlier, it's the regular plug (SPX1600V).
1992 and later, it's the O-ring plug (SPX1700FG).
