Good day
First post here, but have been reading the site for the past few months and it's been very informative.
I have an in-ground salt water system pool with a vinyl liner. I believe a little over 20k gallons.
Hayward S200 filter, Hayward Super Pump 700, and AquaRite Electronic Chlorine Generator.
Over the winter after a deep freeze, my filter housing cracked. Expensive lesson learned about failing to winterize and drain the lines.
I know this model is old, what would be a good replacement?
I've read that keeping a sand filter but replacing sand with crushed glass is one of the best options, and less hassle than dealing with a DE filter. And we were happy with the sand results.
This model is side mounted, but I can modify to be top mounted if needed
Thanks for the help.
