- May 20, 2023
- 2
- Vinyl
- Hayward Aqua Rite (T-9)
I’ve looked through the forums and haven’t found my answer. I’m not sure if I’m being more sensitive this season than last, but the pump seems louder and has a constant, rhythmic, pulsating noise to it. I pulled the basket and felt in the impeller with nothing abnormal noted. I haven’t seen any bubbles in the suction strainer.
What else should I check? Should I pull the impeller to ensure it is clean visually? Is it possible I’m getting air in even though I don’t see signs of it? Could one of the suction lines be clogged? Should I try bolting down everything more secure? Is it a normal pumping sound and I’m just crazy?
Info:
Hayward SP2610x15
One skimmer, two bottom drains
Suction side has one 3-way valve (skimmer, bottom, both)
Video:
FYI the “rattle” noise in the video is coming from the inlet piping at the top of the sand filter, my phone was right next to it while recording. Also you can hear it change as I put some pressure on the discharge piping (trying to see if it is vibration).
Info:
Hayward SP2610x15
Video:
