Installed a new US Motor today to replace a 4year old motor that failed (smoke got out).
I'm wondering about two things (and see my NOTE below about the filter replacement)
1) is the mismatch in total HP between pump and (both) old and new motors okay? I'm told the new motor is a direct replacement for the old, and they do have same total HP. **
2) Is the case temperature too high? After running about 30 minutes I measured 200F. The motor fan is blowing hot air, not obstructed at all.
First photo below shows the temperature measurement
** I think (can't remember for certain) that the original motor with the Hayward pump was replaced under warranty when it failed after about 13 months. So it's possible (likely) that Leslie's put a new but lower rated motor in as a courtesy. In any case, the Old motor worked fine for 4 years until 2 days ago when I noticed it was off due to thermal safety switch. Both new and old motors generated powerful enough jets in the hot tub
NOTE - A possible complication is that I had replaced the DE filter with the next size up. Went from a pentair 48sqft to a pentair 60sqft. I think I read in this forum that upsizing the filter is fine. I did the entire replacement myself, I'm pretty certain that there aren't any issues since there are no leaks, filter cleans, jets in pool and waterfall from spa to pool looks normal. HOWEVER -> the pressure guage on top of the filter now reads about 19 psi with the full new charge of DE, whereas previously I think it was closer to 15 psi. I always fully dissassemble the filter, so it always starts pristine and at consistent pressures.
Summary
- could be that the larger filter (with higher pressure) caused old motor to fail within a week (with 30 min daily runtimes, I was on vacation)
- new motor could be being overstressed
- or maybe the high temp I'm measuring is expected with a higher SF motor
Some more details
Old motor: 1.5hp SF 1.10 ( 1.65 Total HP)
New motor: 1.0hp SF 1.65 ( 1.65 Total HP) This is a new motor, from a reputable local service/supply shop in Austin TX, is new (not rebuilt)
Pump casing label: 1.5hp SF 1.6 (2.4 Total HP)
Hayward pump
New motor
Old motor
Summary
Some more details
Hayward pump
New motor
Old motor
