- Apr 10, 2018
- 5,178
- Plaster
- CircuPool RJ-45
My father-in-law needs help identifying the model of his leaking pump. Water is seeping from the housing/mounting plate. He has already replaced housing gasket.
I believe it's a Hayward Max Flo. It currently has a replacement single speed 1.95 HP motor.
We want to replace the shaft seal with a heavy duty saltwater kit. Will the PS-3868 kit fit this pump? Is there a better kit available?
What other failed parts may cause a leak from the housing/mounting plate area. He's checked the drain plugs and plumbing connections.
Thank you.
Thank you.
