Hayward Pump Identification
Rancho Cost-a-Lotta
2,401
Rancho Cucamonga, CA
CircuPool RJ-45
My father-in-law needs help identifying the model of his leaking pump. Water is seeping from the housing/mounting plate. He has already replaced housing gasket.
I believe it's a Hayward Max Flo. It currently has a replacement single speed 1.95 HP motor.
We want to replace the shaft seal with a heavy duty saltwater kit. Will the PS-3868 kit fit this pump? Is there a better kit available?
What other failed parts may cause a leak from the housing/mounting plate area. He's checked the drain plugs and plumbing connections.
Thank you.
Rancho Cost-a-Lotta
2,401
CircuPool RJ-45
I forgot to mention, the model number is worn off the identification plate and there are no model numbers on the lid.
Rancho Cost-a-Lotta
2,401
CircuPool RJ-45
I don't recognize it.
Look for a part number on the impeller and diffuser.
Thanks James. I'll have him check when he tears it down.
I'm fairly sure it's this series of pump:
Reactions: JamesW
