Where is the water on the copper manifold coming from? What exactly are are you trying to seal with solder? If the well itself is leaking from the outsidof the well (from the manifold) to the inside and has been breached, you would need to drain the water from the maifold and if you got excess solder in the manifold in the process of trying to seal it the bulb may no longer fit in the well. Even I might be pulling out my hair trying to repair this if that is the case.
