I am needing to buy tabs for the first time and I am clueless. Can anyone please provide guidance on what I need? I just know the pool builder said slow release. Thank you!!
I read that before I posted. It just wasnt clear on size of tablets, preferred brand, compatibility etc. Thanks for always responding though!Welcome to the forum!
How to Chlorinate Your Pool
Before chlorinating your pool, you should know these simple tips. Learn the best way to add chlorine to your pool.www.troublefreepool.com
That's because it doesn't recommend using tablets at all.It just wasnt clear on size of tablets, preferred brand, compatibility etc.
Hence this created thread asking for help and clarity.That's because it doesn't recommend using tablets at all.
If you choose to follow the TFP method, using liquid chlorine (or a salt water chlorine generator) is the only thing you would use long term. The tablets cause trouble for anything but temporary use.Hence this created thread asking for help and clarity.
So, here is I believe the answer you are looking for:Hence this created thread asking for help and clarity.
Greatly appreciated! I read the pool school articles and get the problems associated with tabs. My system in place goes against almost all of the TFP recs lol...ozone/uv combo...chlorine puck drip supplement. I do have weekly service where the person adds liquid bleach. Just my luck the ozone/uv unit is broke and and backordered...so right now its just bleach/pucks. I know I know, TFP frowns on ozone as well. Your response was very helpful! A few diff questions as im educating myself and will take over pool duties from the weekly service company...So, here is I believe the answer you are looking for:
What I am trying to do here is to head off problems before they start. You are perfectly free to manage your pool any way you see fit. The TFP method works on any pool in any climate. The people on this forum advocate for pool owners to take control of their pools by performing their own testing and only adding what the pool needs. This in turn leads to fewer problems and long term cost savings. Just my $.02.
- The appropriate puck to add are any of the commonly available Tri-Chlor tablets or tablets on the market that are designed for pools.
- Using tablets routinely conflicts with the TFP method
- Make sure you maintain your FC (free Chlorine) IAW the band specified in the Chlorine / CYA Chart
- If you are going to use tablets, be aware of the following:
- Avoid any Clorox products
- Avoid any product with "Blue" in the name unless you know for sure it does not contain copper or other metals
- Long term use of tablets causes an increase in CYA (stabilizer) that starts to become an issue between 60 and 100 ppm, usually requiring at least a partial drain and fill (See here, here, here)
In theory, but what TFP has found is that is Not Effective. Ozone doesn't persist in the water, so while the water being passed through the ozone generator may be "sanitary" the water on the other side of the pool is still flu soup. and none of the ozone will get back to that side of the pool. Also, there is no way to test how effective the ozone is.1-When working, I believe the ozone gas will reduce the amount of chlorine needing to be added to keep the level proper compared to no ozone gas...can you confirm this logic?
I don't understand this system. Are you saying you have something that continuously adds LC to your pool? If this is the case then just use this system. Whether you add LC in 1/2 gallon increments or in drips continuously through the day, If you keep your FC at the right level your pool will be sanitary.If no one is adding anything between visits, then yes this is the sole source of FC in your pool.2- when chlorine is added since I know the ozone alone isnt enough, liquid bleach is the main way its added each week. Their is a drip that will be on a low dose. I ASSume that is to help the chlorine left throughout the week between services since currently I/no one is adding chemicals between visits?
Yes, this is correct Sunlight breaks down FC, A cover will slow this down. Heat will also break down FC. CYA will also help protect the FC. However, as CYA goes up, you will need a higher FC to keep your pool sanitary.3-I also have an automatic pool cover that is in use whenever we arent in the pool. I live in Charleston, SC. As you can imagine it is hot and direct sunlight. The cover helps block the sunlight from breaking down the chlorine even though its still very hot temps...correct?
Pool Store tests are not very useful. Phosphorous doesn't matter, just ignore it.4-My pool is only 4 weeks old. It is pebble tech plaster. I just got my water tested at Leslie's. The Phosphorus count was 4000ppb. Would you expect this is so high because the plaster is new? Is that a problem? I read in the pool math app that I should ignore phosphorus altogether...??
Thanks! Yeah I just regret not getting a salt system plain and simple. I also don't have the time to manage the chemicals daily or multiple times during the week, so I feel like all I can do is have the puck drip during the week and the weekly service tech add liquid on Fridays. I never would have bought the pool if I would have to manage the levels with my current life and family stage.Man, there is a lot to unpack here:
I will give you my patented NEW to TFP Standard Rant:
Read the book, buy the test kit, add Liquid Chlorine for your Cyanuric Acid as directed (Probably have to SLAM for a little bit), enjoy your Trouble Free Pool
Here's the thing, nobody here is trying to make money off of you, we have no interest in selling you any gizmo's or products. The Pool Store/Pool Company sees dollar signs every time you walk through the door, and there goal is to extract as much green from your wallet as possible. The advice here is solid, backed by empirical data and years (sometimes decades) of experience with all types of swimming pools and all of the problems that come with them. So you have to ask yourself, who has your best interests in mind, and who's going to do a better job taking care of your pool, you (backed by this site and a solid test kit giving you known results as frequently as you need them) or some guy at a pool store who is at best a teenager who doesn't have a clue what he's doing, or at worst someone out to fleece you for as much as they can get.
/end rant
I will also add, I know you invested all this money in these Gee Whiz gizmos that the builder sold you on, and you don't want to think maybe you got taken advantage of. But, that ship has sailed, and all you can do from here on is do the best you can to manage your pool properly using the tried and true TFP methods. Follow the builders instructions for the break in period to retain the warranty, for what little that's worth, and after that follow the TFP method. Ozone doesn't work. Pucks are problematic, pool store tests are mostly worthless. Just my $.02, take it for what it's worth.
You can buy 3" or 1" tab but get 98-99% Tri-chlor and find an MSDS before you buy, so you know exactly what you are getting. Avoid the 3-n-1, 4-n-1, 5-n-1 etc. Those are the tabs that have extra compounds that can get you in trouble.I am needing to buy tabs for the first time and I am clueless. Can anyone please provide guidance on what I need? I just know the pool builder said slow release. Thank you!!
