Hi All,
So 2 days ago my T-Cell-15 chlorinator stopped working (I have the Prologin Panel and rigid plumbing). For reference, I installed everything brand new late July last year so it has <4 months total use on everything.
I am getting the error "chlorinator off - no flow". I pulled the board and checked and all the solder points looked fine. I then took the flow switch out and tested it and it also works fine. I then tried turning my pump on high (I never use high speed) and it got flow and chlorinator turned on.
So, I backwashed the sand filter (I had done it about 1.5 weeks ago due to the pollen) and tried again and same situation. I am seeing ~4 psi on low and ~14 psi on high. I run the pump 6 hours overnight on low and have done so for the 3 months last year and the 1 month so far this year - salt chlorinator always worked, never had an issue with flow. Now it only senses flow on high.
Here is my plumbing setup - the flow switch is installed directly in front of the salt cell and the arrows are pointing towards the pool.
Thoughts?!?
Thank you!
Thoughts?!?
Thank you!
